i am working on a part trying to modal a cable head assembly i have ran into a problem trying to put wrench flats on a cylinder type shape any pointers will help.
Can you create a rectangle and do a push pull? @ClayPhillips just draw a rectangle were you want the flat? @MikeJones86
I can defiantly help if you need it. I just would need a rough drawing with some dimensions.
