https://www.autodesk.com/shortcuts/inventor#one-key
I was asked to make this a Thread so it Searching it is Easier. I will try and stay on top of some programming help links that I have used over the years. If it helps others program easier, and learn some different ways to program to help broaden knowledge.
Thank You Mike. I am new to using Fusion 360 and allwase thankful for tips and tricks to get the job dun faster. I will print this out and put it by my PC to speed things up.
https://boedeker.com/Technical-Resources/Technical-Library/Plastic-Machining-Guidelines
This is a good site for multiple purposes on Milling, Drilling, Saw, Turning, and even Coolant when messing with Plastic materials.
http://www.carbidedepot.com/formulas-milling.htm
http://www.niagaracutter.com/speedfeed
Nice Feeds and Speeds Chart
I usually go for the middle range then adjust my Feeds and Speeds according to the Sounds and Finish on the part.
https://www.newmantools.com/key.htm
This is a good one also to have when doing Keyserts
http://theoreticalmachinist.com/IsoTolZoneCalc
ISO Tolerance chart
