Warning: Lifting feed plane to topmost ramp
I got this warning during the 2D contour operation of the titan M1 and I’m not sure what caused it or if its safe to run ant help please
Warning: Lifting feed plane to topmost ramp.
Generation completed with 2 warning(s) in 1.5s.
You might look and make sure that you have all of your clearance height lift Heights set to what Titan has in the video you might not have it set properly
Turned out the setting for the end mill to hilicoil down was set at .1 just like the feed height I set it to .05" instead and it fixed it
Yeah I have made it to were I changed my clearance to certain heights so I have hardly ran into it over the years now.
