Hi guys… Please bare with me… New to this nc machining, recently bought a haas vf4 for drilling our own wheels… ( just pcd)… Woukd anybody have and ideas on getting the route for the different pcd patterns.
Thanks guyd
Thanks guyd
Are you referring to the bolt circle diameter on the wheels?
Yes indeed buddy… To be honest at this stage we would be happy to send a pro the dimensions/drawing and if they could help it would be great. It’s a bit of a mind field, basic milling etc is no problem, the issue is we are doing these on our own wheel designs, they are coming from the factory as a finished product except the bolt holes drilled, and we don’t want to chip the edge of lacquer where the hole is drilled
@MikeJones86 hear is your opportunity to do some contract programming you are familiar with Haas machines.
I can help you with the patterns no problem @JoshSpence and thank you @Rumpelstiltskin for the referral
Mike Jones you are a gent. Have you a WhatsApp Contact. We are based in Ireland so the time difference might be tricky. Thankyou rumplestiltkin aswell. Great help
@JoshSpence if you want Mike to get a message you need to put a @ in front of his name it is caled tagging him he will get an email notification to alert him of your current circumstances. Here I will tage him for you next time you give it a try. @MikeJones86 you can also send him a private message.
@JoshSpence No I haven’t heard of that before. I will look into it and also I’m going to send you a Message with my personal email.
@Rumpelstiltskin thank you sir
