Taper control
I use to run a CNC lathe/ Daewoo Puma with fanuc controls and there was a code for taper control I forgot what it was! does anyone know what it is?
This should help been a while since I have been on a lathe.
http://www.helmancnc.com/taper-turning-with-g90-modal-turning-cycle-cnc-example-code/
thanks mike but I’m not turning a tapered finish I’m turning a shaft in between a live center so your x will have a taper
