Second Operation (CAM and Machining) of Titan-10M
The second op on the 10M has caused a lot of trial and error on my part… ( mostly error ) :slight_smile:
Tim my tool path strategy is similar to yours… The secret to the second op lies in using
“patch”. So that your parallel tool path will not dip down into holes and give you that Titan finish…
It will also help with the earlier adaptive tool paths… here are a couple of links to two short videos on how to patch…
Worked like a charm…
Patch Part One
Patch Part 2
Here is a link to my tool paths for the 10M
https://a360.co/2JoOCft
Any constructive comments are always welcome…
Also my project is being machined on a Tormach… So the tool paths are not as aggressive as the larger machines…
Hope this helps…
John
