G94&G95 Code
Can someone explain the G94 and G95 code? I run a Yami Seiki Vertical Mill, I notice we use the G95 code. Example 3 inch FaceMill spindle speed 1000, feedrate F.030. Does G95 have any relationship between spindle speed and feedrate?? I’m still learning this topic, and whats the difference between feed rate and surface speed? Thanks
G94 is mm/min
G95 is mm/rev
