Hello im clay and just joined today!
i work at a machine shop in Hubbard TX. the owner actually introduced me to this academy i have a strong passion for this line of work. im just looking for a little guidance on this academy. ,
                                                               thanks, clay
Welcome to the group:grinning:
Since the owner of the company you work for has suggested you take interest in this forum and the education series (building block and rocker series) is a good sign he sees potential… Good luck!
Great to see you hear welcom!
is there assignments that i can do on this academy? so i can check my progress on learning as im going along?
Have you started the building blocks yet on https://academy.titansofcnc.com/
There are lessons/tutorials, but no formal training system that records your progress. It is currently designed for self evaluation. If you run into road blocks or need further help, search this forum with keywords, if you cannot find an answer find a category and post for help. People on this forum are pretty good to get you on the right track.
okay thanks Stephen. and yes i have started the building blocks. majority of the software is pretty basic to use and pretty simple.
when I download fusion 360 do I need to download the free trial or student I tried the student but it cant find titans of cnc academy for the education part
I see they (Autodesk) may be experiencing some problems with new education licenses. You should also qualify as a hobbyist or startup… You might consider that route. https://www.autodesk.com/campaigns/fusion-360-for-hobbyists
