Deep pocket in alluminum
hi guys. any ideas how to machine pocket in alluminum? lets say that dimensions are 100x100mm. problem is that the depth of cut is 60mm and t radius on edges is 3mm.
Can you share a model? The other question would be is there an opportunity to drill the corners out then go in there with a larger Mill and finish afterwards?
Use a bigger tool to get most of it. Finish it up (rest in some CAM softwares) with a reduced shank 4.76mm end mill from Maritool. 60+ is pretty far to stick out. Keep RPM on the low side to prevent chatter. Multiple depths etc. to get the wall finish good.
Hi Marko.
For me you need four steps:
1- drill the corners by a 5.9mm ,
2-open poket by a 12mm mill
3-pre finish corner by an high feed 6mm mill
4-side finishing by parabolic mill (5 axes motion)
OR if the poket is pass-through you can simply made 1 hole and then make the pocket on a edm wire machine.
Hoping useful , Have a nice day
Agostino
Drill the center out oversize of end mill your going to rough with. Ramp down sling some chips don’t be afraid. Lastly finish with a long reach stub flute end mill with a radius.
