Fusion/Haas Questions
Hello all. Recently received my Haas TL-1 & have been running a few simple programs I drew up in Fusion. Being as it’s a fairly basic CNC lathe, it didn’t come with all the whiz-bang options like a chip auger or motorized tail stock, which is fine for my intended use.
Question though. When I post to the lathe, I always get a M22 & M31 in my program. I’ve looked & looked, but can’t find anywhere in Fusion to prevent it from doing this. Any help would be appreciated.
Aside from that, Fusion seems to work pretty well for the most part, aside from crashing every now & then when I try to run a simulation. It just started doing this about a week or two ago, right after an update. Hopefully they fix that soon.
Thanks in advance.
I would have to wait till tonight to be 100% sure about Fusion but if like Inventor you can edit your Post Processor easily. When you post out the job it first comes up with a post processor dialogue box and in that you can change various items for your needs.
There are usually parameters you can turn on and off in your post. See if your post allows any changes, you can review this post where we wanted to turn off the live center. Avoiding Live Center using Fusion 360
