Hi, im using fusion 360. The qustion is whats your workout, when you get step model with some holes to drill. But in technical drawing they have position tolerance +0 +0.3 mm. Do you have to fix model or is there any easyer way. Thanks
I would think if you were using cutter compensation to control the diameter of the hole it would not need to change the model.
