I’m having problem with drilling and tapping M2 x 0.4 hole on CNC mill
What are the issues? Is it chips in the hole? Tap braking?Using oil or coolant?
Tap breaks inside hole. using coolant with 20% concentration. Material 17-4PH is HRC 47.
Tapping M2 x 0.4 drilling hole with carbide drill 1.68 MM.
@KAZIMIERZALESZCZYK it looks like you’re doing it right. You might try some molly D oill.
@KAZIMIERZALESZCZYK did you make it through? Did you get your parts taped?
