Mastercam 1M regeneration
I just got Mastercam downloaded and did the 1M but when I go to save file keep getting a regeneration
error . If I save anyway when I open it I get the wire frame no holes no solid? Can anyone help Thanks Roger
@Nicole Can you help Roger?
You will have to redraw the model once saved if you clicked yes to the regen error message. I suggest that after you are finished drawing the model, you turn off the model history under the model prep tab. This will solve the regen issue and allow you to save as normal. You could instead look under the solids tab to see what solid is having the regeneration issue and fix whatever the issue is. It’s most likely due to a chain that has been broken after extruding a solid and needs to be reselected.
