Titan 1M - 2022 Mastercam - OptiRough Computation Error Help
Hello,
I am currently working on programming the Titan 1M project in 2022 Mastercam explained in the OP1 video. I am running into a blocker, as I can’t get the optirough function to rough out the part after the initial facing section of the video (~30 minutes in). Instead I receive a “reporting computation error”. I’m very new to this, so none of this may even be applicable, but I’ve checked that the model geometry entities match what is on the video as far as number, rewatched the design video and redone the part to make sure I’m not missing anything there, confirmed my origin and plane match the described in the video, and unfortunately just can’t get the toolpath to run. I had no issues with the facing portion prior to this portion of OP1, but am now stuck.
Any chance someone may have run into this in the past and would have some recommendations on how to potentially fix the issue?
Thank you in advance.
If you can, go to the Titans of CNC FB page, the Titan crew will see your request much quicker.
Thank you.
Finally figured it out. Had to create another stock model to reference. Once I did that I was golden.
