Set up M1 set up in cam
I’m trying to set up my xyz in cam I’ve selected everything correctly but I have it on model box point and I can’t select top left dot it says unknown selection. What am I doing wrong
click on stock box point if you are using the material edges. if the corner dots don’t show, click a different option then come back to the stock box… I’ve had trouble getting points on the stock box sometimes unless I switch to another then back. It might be the same for the model box
Reason for this is, the CAM thinks you want to use same point as the model WCS. If it’s a 90degree corner, just use selected point and select your point. This is a simple/stupid bug that has been discussed in the Facebook group multiple times.
Also if you still can’t, just draw a sketch with the point you need.
Personally I would love to see one more option to selecting WCS. Selecting X Y and Z as separate planes.
This can sometimes speed things up by skipping making an extra sketch.
