Setting up fixtures (Part Two)
Ok, I have found the fixtures in Fusion. However, I wanted to use them in InventorHSM also but when I export them to Inventor, they don’t work properly. Does Inventor have fixtures and vises that can be used to program with? If not, I will program in Fusion from now on. I like Inventor but I need the fixtures.
No the data does not translate over you lose the parameters and joints, as you have to send it out as a dumb model unless you have A fusion team hub.
With the team hub you can work on the model in both fusion and inventor, I have only done referencing between the two, I thinks It’s about time I tasted the translater out. back soon.
Yes!! I found out the hard way. Can I get the translator off the internet? How do I get on a Fusion team?
It a cost to have a fusion team hub, you still lose the parameters, joints and sketchies if you convert the file in Inventor (first time I have tried this).
You can convert the file and set it up with joints and parameters in Inventor, you just use the same parameters and joints that fusion use’s.
