Having trouble getting the pocket cut outs with the .100 depth to cut on the outer profile. any help???
@Billy-Boyce can you help?
Hello,
3 questions
- Are you using Fusion 360?
- Are you following the video? https://academy.titansofcnc.com/video/titan-96m start at 14:20 for this feature
- What part of adding them are you having an issue with?
I am using Fusion. I was having trouble projecting the profile to be extruded down on to outer profile. I will reference the video and check back, thank you!
After watching the video I figured out I need to also check (Chain Faces) on my selections and it did do the cutout. Thank you for your help @Billy-Boyce!
Awesome glad you were able to figure it out…
