I am trying to offset a line on Titan 1M (.300 wall). when I go to select line/curve it will not select.
I did reboot - got update Sept 4 - still won’t work.
screen cast - no audio
I believe I duplicated your problem. If you turn on your sketch to view, see if that helps. At the end of this video, I turned off my sketch view and was unable to grab the offset
Cantsee line offset https://knowledge.autodesk.com/community/screencast/187420ac-3e39-44a5-826b-59b5d117b7c2?fbclid=IwAR2xwVheJf_5yxUWxWOYI00ODEKnb7C7LOhrqbM3Yd-0RMmVv1hIVG4NJQw
I was able to go back and edit sketch 1 and that worked to turn sketch back on later on history wise
My current problem is that if you have all sketches on you can’t Offset - or sketch to lines or curves that were created in sketch 1 or 2. You have to go to edit sketch of sketch 2 for example
You can turn off being able to start sketch then do an offset from an edge, if you have it set like the attached pick it will work fine the video I did the other day I showed what settings to have set.
Hey that works ! thanks - I was doing it as sketch a rectangle and fix. then I had a hard time making the Circles concentric to the bolt holes. I had to return in edit sketch 2 to associate it better and hide the view of other sketches. and stay in one sketch only so that it stay associated.
THANK YOU!!! that helped I tried using just a rectangle but that quickly runs into problems like not allowing the center of the circle to land in the middle of the holes
