Titan-10M web issue
I encountered a problem when making webs. I tried redrawing them but nothing seems to work. I checked this board but did not see an answer. They keep selecting various parts of the web and not just the ones I want.
https://a360.co/2pbpbCT
@Billy-Boyce do you have a solution? If you do, can you make a video and make a Titan M solutions page to post it on for others?
Thanks,
Brian
It took me three tries and having to start completely over each time before I got it right to draw the Hexes. I have one student that has been working on the web offset for over a week. I tell him to follow the instructions step by step in the video. I believe his is trying very hard to follow the steps exactly, but something keeps hanging him up. I have been unable to correct it, when it comes time for him to pick his offsets, so I have him start all over again with his sketch of the hexes. I am beginning to think it may be a software glitch or hardware glitch. I will be working on this today again with my student.
I tried about 5 times. Each time it got worse. The only thing I found was to use the BREAK command to break the Hexagons into lines and go from there. I am now onto programming the part.
I think the Fusion team needs to look into this and you should only be able to click lines to guide 360 much like the procedure for the 9M surfacing.
Its finicky tool to say the least but when you get to work it’s a blessing. Glad you were able to figure it out.
im having the same issue,im trying to draw out this project in model in fusion 360 and when i try to web the edges it selects all of the crossed lines and when i extrude it makes diamonds i followed the video to the T and cant seem to figure out what im doing wrong
Sorry for my late reply. Did you ever get it working?
i did, i made the polygons with out the construction line and it worked fine, thank you
