it seems I have a different version then what is in the 1m-4m videos. (4m is as far as ive gotten) its not always a problem I can figure out work arounds sometimes. but in the 4m project when it comes to presspull the corners down for what ever reason my fusion wont select those corners by themselves like yours does… and it took me forever to figure out that the second set of options in the sketch menu you have (which doesn’t shoe up on my version) is now in the top toolbar. so I moved my circles to the edges using the tangent feature as per the video you provide and it doesn’t separate the object the same way, so I cant presspull it. I think if I do it before I do the drill holes it might work but that’s time consuming when the class is about being timely and efficient. I realize its free to me and many thanks for that! im just struggling to match up my version to yours for what ever reason.
It may be your sketch circles are not tangent to the triangular sketch. You may want to create a relation where the radius is coincident with the edge of triangle… Okay, I saw in your first image where you where able to select the inner portion minus the corner and three circles. Have you tried to right click the three corners? You might even try and trim the inner portion of the three circle sketches.
I tried all that. gave up started over and did 2 push/pulls one at .375 and then sketched on the circles and did another push/pull. seems to be working so far. thank you again Stephen! I really do appreciate your time.
