hi guys , can anyone help me on line , how i can share my job in fusion 360?i have problem to setup and machine with 4 axes, please help:sweat:
skype alessandrobrogli
Hi alsssandrobrogli in a nutshell you just had the cut set wrong.
Your set up was fine
To get a toolpath you can only use 2D contour, 2D adaptive and 2D pocket at the monent, there are some other toolpaths you can use in beta here is a link to it http://manufacturinglounge.com/hsm-beta-mode-hsmwork-inventor-hsm-fusion/
What you do is pick the contour you wont to cut then pick the faces to use as the references this gives you a wrap toolpath.
There is no 4th axis continuous milling in fusion yet
thx for your help my friend
