Programming
Good morning,
I have noticed in the training modules that the cube in the upper right corner and the model are not in the same orientation when programming in CAM. Does that matter? I noticed that Titan didn’t change the orientation. Thank you in advance for any help on this.
Darroll Hough
If you are talking about Fusion 360. What orientates the part is in the setup settings. How the arrows on the part look.
Its how you set up this little UCS red geeen & blue arrows that determine weer XYZ is oriented
