I’m trying to program the Titan 1M block.
When I click on New Setup, the Z & X arrows are pointing in the correct direction but Y is pointing towards the back of the part.
The video shows the Y axis arrow pointing towards the front of the part.
Any help would be greatly appreciated.
Thank you for your time.
the software allows you to select 2 axis. if you selected your y axis, there is a small check box that says flip axis. try this.
Good Afternoon:
No matter how many different ways I have tried I can’t get the X Y Z arrows to pointing in the same direction as shown in the video.
The closet I have come, is the X & Z axis are pointing in the correct direction but the Y axis arrow is pointing to the back of the part when in the video the Y axis arrow is pointing to the front of the part.
Donald Hollingsworth
Good Afternoon:
When I try this, then then X or Z axis arrows will be point in the wrong direction.
in the orientation tab, there are selections for Z/X, Z/Y and X/Y. select Z/Y, click the top surface of your part to set z, then click the front face of your part to set y, then click the flip y axis check box to set the direction of your y axis. if z is pointed up and x is pointed to the right, then y will always point to the back of the part.
watch this video at 5 min 45 through 6 min seconds.https://academy.titansofcnc.com/series/titan-1m/how-to-program-the-titan-1m
Good Morning:
Thank you for the information. That really helps.
Donald
