Reset Work Offset or Tool Length to Zero?
I am looking for a shortcut to reset a value for a work offset or tool length to Zero on a Haas control panel. Currently I am entering a value opposite current displayed value so the new value equals zero.
(-1.2013 + 1.2013 = 0)
I assume there must be a key on the control that will do this but so far I have not found it.
Thanks,
Chuck
Hi,
which have you on HAAS?
It is a TM1p mill. I think from 2014.
Use origin key to clear your value to zero. You can also use origin to clear an entire column of offsets or single tool
Ah, the Origin key.
Thanks Stephen.
Press 0 then F1. F1 writes. Enter adds to
x2 with Bradley 0 F1
Haha I remember these days. They’re right.
F1 will “over-ride” the value to whatever you type in. So if you want .005 but don’t want to add .005 to current displayed value. Press F1 instead of enter. It will change the value from X to .005.
