Hello: all was going to set tool and work offsets, and got big numbers showing for offsets. After some digging I found setting 64 turned off , should this be turned on to acknowledge g43 code in the cam produced in fusion?
This is straight off my UMC750SS Next Gen Controller,
64 - T. Ofs Meas Uses Work
βThe (Tool Offset Measure Uses Work) setting changes the way the [TOOL OFFSET MEASURE] key works. When this is on in ON, the entered tool offset is the measured tool offset plus the work coordinate offset (Z-Axis). When it is OFF, the tool offset equals the Z machine position.β
Hope this helps.
-Bear
