Hi I need help trying to work out how to get the correct stock shape, to machine, i turn on a Goodway GLS200 cnc lathe, my parts, then i transfer them to a 5th axis Victor Ax380 machining centre, the problem is i am trying to use the modelling software in Autodesk inventor cam to only machine the specific arias. but the the shape is not from solid, how do i get the right shape solid over my turned part to machine.
Need much more information 1) is your stock from bar (round or rectangular) or a casting? 2) Are you wanting to transfer the unturned stock to your 5th axis machine? Pictures or drawings of your problem would help.
Hi Alan , now fusion 360 has got the skill to load the setup stock “from previous operation”,
Let check if Inventor (same software house) has too.
Hi TITANS
I have attached my design drill bit, i am looking to machine in a Victor ax380 machining centre, mounted 10" hydraulic chuck.
The items is Turner and heat-treatment to 45HRC using D6a steel.
I am trying to crate stock around the item and machine the side flutes using a harvi 2 5xD end mill 6mm or 8mm.
Time is the target hear, i am looking to machine the side relifes using the full depth of cut and trichodal milling. Then move to the next relief.
I also need to mill the top three water channels and drill all the holes. Using 5th axis.
How do i do this in fusion 360 or investor cam.
Kind Regards
Alan Scrooby
P.O. Box 1104 Honeydew, 2040
Cell: 064 667 0344
E-mail: alan.scrooby@gmail.com
E-mail: alan@ragnarrocktools.co.za
Nothing in this message is intended to constitute an electronic signature unless a specific statement to the contrary is included in this message. Confidentiality Note: This message is intended only for the person or entity to which it is addressed. It may contain confidential and/or privileged material. Any review, transmission, dissemination or other use, or taking of any action in reliance upon this message by persons or entities other than the intended recipient is prohibited and may be unlawful. If you received this message in error, please contact the sender and delete it from your computer.
(Attachment 54R3239TF3T.ipt is missing)
