every time i try to do the webbing on the project, fusion crashes
Have you looked at the fusion website for info on that?
I actually got it to work by not making construction lines on the polygons
Continuing the discussion from Titan 10M Help:
I have had several issues with drawing the webbing on the Titan 10M project. I could not get the webbing function to select the proper lines. I followed the video multiple times and either had errors which would not let me draw the webbing at all, or portions of the drawing which were not suppose to be webbed got webbing. I tried not using construction lines on the top and bottoms of the polygons and that got me close but was still giving me trouble. I finally got it to work by not creating the construction lines and not creating points as described in the tutorial. I just snapped to the intersections on the polygons to draw the crossed lines and everything worked after that.
I had the same problem. I kept getting errors about not being able to use intersecting lines
I had the same problem, and so I tried eliminating the construction lines and the points. Still no luck. After several retries, I deleted the design and started over. This time, without using the construction lines and the points, the web worked perfectly. Seems that Fusion has a deep memory of things that don’t always go away when you edit a sketch. Pretty nifty when it does work.
