As I was using the 2d contour to machine around the islands in TITAN 6-M with 1/4" flat end mill…after genarating the tool path its showing a warning that " cannot plunge outside the stock ".
need tips how to overcome the above warning .
Curious, let me know if the error goes away if you eliminate any lead in or lead out factors, including the vertical lead in. Your error maybe a result where your tool start to move to your cutting path is running into something.
if I am eliminating the lead in or lead out it is showing that it has to be given a value as wear compensation is activated…
You might try two things then.
- Turn off comp, chose for compensation, using computer, see if that eliminates the error
- Check to see what diameter you have in your tool offset page. Zero out the diameter to see if that eliminates the error.
I have tried what you suggested but couldn’t overcome the warning.I was doing in the same way as per the Titan 6-M video. Even in the video warning has occured but no solution was shown.If you don’t mine just see the video once or you give a try to find the solution and it will useful for others also in future.
Thanking you Sir !!!
Thanks a lot Sir !!! It worked.
Is it necessary to use Wear comp while finishing the component ?? If Yes why are we not able to use in the Titan 6-M for above issue I have asked you before as you opted cutter comp to ‘in computer’.
Can we use a smaller tool than 1/4" end mill so that we can opt ’ wear’ in compensation option and we can use multiple roughing passes just like the TITAN 6-M video made by Titan Gilroy.
3.The solution given by you regarding the previous problem does it differ from the TITAN 6-M video made by Titan Gilroy…??
I am pretty sure it worked using the wear compensation. I opt to not use the wear compensation to prevent any aw shits when they run the part in the machine. If someone has a value in the tool offset page, you might snap the 1/4 endmill. It worked for me when I used the wear compensation, if you could snap a picture of linking page
