Master cam postprocesser
Is there going to be a post processors made available to use the mastercam Home Learning Edition for some different VMC’s namely HAAS for academy projects?
Mastercam HLE is for training that’s whey its free it won’t post code have to have the full version. If you do program something and want it posted I have herd that they can change the file to a regular mastercam file so it can be posted
So in the end we can not use mastercam hle for Academy projects, !
At our school we have full edu editions - so any HLE will work if posted thru a full EDU version.
the suffix for HLE or EDU school is *.Emcam
no conversion needed
and pro version is *.mcam - So you can’t open an *.emcam in a *.mcam pro version (like at work) but I have opened *.mcam files in the EDU or HLE version
Mastercam 2020 HLE functionality
So we are just learning - but if you have a CNC and don’t have any software? You should think about that.
