I’m working with an old Biesse Rover 346.
When doing a side drilling operation a couple of times i realized the holes aren’t getting drilled in the center anymore, but rather too high.
The problem persists when doing milling or drilling vertical holes. So it seems it’s the whole “carriage” is misbehaving.
First time running a program it runs correct, but if I restart the same program it will have moved the Z-Axis 1-2mm up.
The DRO still reads the correct value, but the cutting bit is not at the right Z-Height.
Any help getting me in the right direction would be greatly appreciated!
Ps: new to the industry and terminology, and not natively speaking English ![]()
