Problem fusion 3m manufacture
I completed the 1m and 2m but for some reason the 3m is causing me problems.
In the clearance height for the o ring Grove you are supposed to select the o ring groove in the heights, of the 2 d contour about 11:53 into the cad cam tormach video. But when “selecting” the bottom height I cannot get it to select the Grove. I can select the bottom of the part or the very top of the part but not the groove.
Help please. Pulling my hair out!
Have you tried using the right-click on the mouse, it should offer you multiple choices when you try to pick the contour line at bottom of slot.
Hi Stephen, thank you for the response. I have attached a picture. I right click and the options come up… I select contour but then nothing halogens when I left click to select the contour of the part. It never highlights.
Thank you for your help,
Aaron
Okay, I will assume you picked the contour at bottom in the Geometry tab
You then select contour selection for the bottom of slot in the heights tab
Hello! Thank you for your question. When selecting the groove, we suggest all of your sketches are toggled to “off”. Active sketches can interfere with your selections. Click the lightbulb next to your sketches to toggle them off (the icon will turn from yellow to grey).
If you experience further issue with the part, please submit a full screenshot (preferably captured with a screenshot application).
Thank you for stepping in, @StephenHadwin!
