Issues with BB projects
Has anyone had issues in the CAM portion of the 3M doing the 2D Pocket or Contour not being able to select the bottom of the pocket under the Heights tab? Haven’t done any in a while, noticed some differences in Fusion from the video and the current version. Thanks in advance.
@Billy-Boyce can you help?
Try this, when you select your geometry, select the bottom contour edge of your pocket. then when you contour, pocket or 2D adaptive process, go to the height tab, then for Bottom Height, select “selected contour”
Thanks I’ll give that a shot when I get home. Ran into the same problem with the O ring groove. So we will see what happens. I’m teaching myself Solidworks for work, but trying to finish the building blocks. Our small group kind of fell apart so kinda got out of doing it. Once again Thanks for the help.
Yea Dwayne. Really miss #27. I might have found a person willing to give me some time on their VF2SS to finish the Mill projects. Just have to travel almost 3 hours to get there.
Worked. Thanks for the help. I think with the updates some of the functions have changed within the Adaptive and Contours.
